my rod knock (maybe)
mk3ftMFw
Mini Toon Burnout!! FTW!!
Jan 24, 2007
95
Cincy
So its a tick, not a knock. I thought it would start as a tick and eventually get worse.
I took off my valve covers and all i can see is where the cam shafts push down on the little button to move the valve. What should i be looking for in terms of a damaged valve?? I guess my question is how do i diagnose a thrown valve?
thanks for the help. Hopefully its not a rod knocking. The noise gets pretty loud, the higher the rpm's the louder it gets.
loki2043
645
Portland, OR
check your clearences on your valve shims. per the tsrm. its prolly just out of spec which makes a bigger gap and a nice tick. OR you exhaust manifold is loose and your hearing the ticking from there..
or your lovely screen name did you in!
loki2043
645
Portland, OR
suprapower1221 said:
I thought i was having a rod knock problem until i opeded the hood and noticed i have a missing manifold stud.
my point!
i had a ticking for a long ass time.. knew it was the valves but didnt want to tear into it yet. now im doing my rebuild and realized a shit load of the exhaust studs were loose.. so thats where the ticking is from, i hear from a lot of people
billspreston01
555
North Carolina
the exhaust manifold is held on by studs sticking out of the head with nuts holding the manifold on.
check your exhaust nuts/bolts/clamps/gaskets whatever.
and check your valve shim clearances according to the tsrm like ^^^^^he said. good luck
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Itsarodknocklifeforme said:
your talking about the exhaust manifold? whats a manifold stud? you mean bolt?
Bolt equals threads / head in one piece
Stud = just a threaded 'rod'
Nut goes over the stud for tightening
mk3ftMFw
Jan 24, 2007
95
Cincy
ok yeah thanks guys... I looked and didt see much. The studs were all good. the ticking sounded more like it was coming from a valve, is their anyway i can get a better view of the valves........
mk3ftMFw
Jan 24, 2007
95
Cincy
I thought i saw a picture around somewhere of someone that had lifted off the head with the black still sitting in the bay.
Anyone done it? Easy, Hard, Not possible?
mk3ftMFw
Jan 24, 2007
95
Cincy
im not quite noob, not quite veteran. More like veternoob.
Well I guess its time to rip 'er off.
thechori
supra-deprived
Oct 3, 2006
567
houston
i'm pretty sure you're still a noob like me if you didn't know that you can pull the head without lifting the whole motor, it's all gravy though
mk3ftMFw
Jan 24, 2007
95
Cincy
well i've done it before on a 2.2L shelby turbo motor, but compared to the 7mgte its an rc car motor.
loki2043
645
Portland, OR
ahhh 2.2 turbo... thats what i had before i came to supra land! a nice 87 daytona shelby Z with T tops, leather.. all the goodies. boy i had fun in that car! until everything started to blow in it.. including the fuel pump which made me say FUCK YOU DODGE! lol. too much work for the state that the car was already in.
anywho. the supra is gonna be a little bit more complicated with the head but you shouldnt have too much a problem with a little help
mk3ftMFw
Jan 24, 2007
95
Cincy
will i need a hoist to get the head out?
anyone know off hand how much the 7mgte weighs... just to gause of how big of a hoist ima gonna need??
88supraFAST1
7M WHAT
Feb 8, 2006
421
Battle Ground, Wa
the 7m's are heavy i think they are more then a V8 but there not that much i have a 2ton hoist and it pulls them out like a lose tooth.:biglaugh: i also have a 10ton hoist at my dads house that is a beast it picked up the front of my 74 duster like it was nothing.
