I've had a major exhaust manifold leak, found out that 5 of them were loose and 3 studs were stripped. Ordered the driftmotion 7/16 stud kit and had a major leak somewhere on the block (turbo lines and oil cooler lines). Also leaking from my valve covers, so I decided to fix all of that and convert to a full flow oil system.
I bought
a mishimoto oil cooler 10 -an fittings aeroquip socketless hose and the other stuff. It was some long tough stuff and drilling into the head was no easy task with the engine still in the car.
I've been driving it about a week now with this setup and I'm blown away. The oil pressure is consistent and there when its supposed to be. my coolant temperature is slightly lower because it doesn't have to work overtime cooling the hot oil (I'm assuming). And when I open the hood to check my engine, the engine bay temp is a lot lower. Its usually substantially hot under there.
All in all it was worth the work and cost. I could've used cheaper parts, but I'm glad I spent a little more with the socketless aeroquip stuff, it made life A LOT easier.
I recommend for anyone who hasn't switched to a full flow to do it, I can see why it'll keep the engine alive a lot longer.
I bought
a mishimoto oil cooler 10 -an fittings aeroquip socketless hose and the other stuff. It was some long tough stuff and drilling into the head was no easy task with the engine still in the car. I've been driving it about a week now with this setup and I'm blown away. The oil pressure is consistent and there when its supposed to be. my coolant temperature is slightly lower because it doesn't have to work overtime cooling the hot oil (I'm assuming). And when I open the hood to check my engine, the engine bay temp is a lot lower. Its usually substantially hot under there.
