My Quick Extender Pro Review After 6 Months – Real Results and Honest Experience
powerdude
22
Hey guys
Wanted to finally drop my full review of Quick Extender Pro after using it for 180 days. I had so many questions before starting, and now that I’ve gone through it personally — I figured it might help others looking into it.
I’ll go over:
  • What package I bought
  • What’s included
  • ️ Assembly & first use
  • My full 6-month routine
  • Issues I had and how I fixed them
  • ✅ Real results (+ measurement tracking)
  • ✍️ Daily journal and consistency tips
  • Pros & cons from my perspective
Step 1: Ordering the Device​
I ordered directly from the official site here with a 20% Discount!
After doing a LOT of reading, I knew I didn’t want to mess with sketchy resellers. Plus, they had a 20% discount and money-back guarantee, which helped me commit.
I chose the Deluxe Standard Edition for $349 with a 20% discount — not the cheapest, not the most expensive, but it had everything I felt I needed to do it right.
They also offer:
What Came in My Deluxe Package​
Here’s what was in the box (really solid packaging btw):
  • The full DSS system (Double Strap Support)
  • 4 elongation bars
  • 2 comfort pads + 2 extra silicone tubes
  • Memory foam pad for the base
  • Instructional DVD and manual
  • Travel case + spare parts
  • Measuring ruler
  • Set of alcohol wipes and gauze
It felt premium but practical — like they knew I’d actually be using it every day, not just unboxing it for show.
️Assembly & First Impressions​
First build took me maybe 20 minutes. Not because it was difficult, but because I kept watching the video and re-reading the instructions. Once I did it once, it became muscle memory.
I’ll be honest — the device looks a bit intimidating at first but once it's set up properly, it’s surprisingly comfortable. The Double Strap System (DSS) was a game-changer — way more secure and stable than cheap knockoffs I tried years ago.
Fitting it the first time took patience. I started small (just base + shortest rods), made sure the straps were snug but not choking circulation, and wore it for 1 hour max the first day.
Click here to use my personal discount link(20% OFF)
Month-by-Month Routine (Newbie-Friendly)​
Month 1: Breaking In​
I treated it like the gym — start slow, stay consistent.
  • 1 hour/day for Week 1
  • 2 hours/day Week 2
  • 3–4 hours/day by Week 4
  • Always took breaks every 1–1.5 hours
  • Used baby powder under the straps to reduce pinching
  • Wrote everything down in a simple Google Sheet (time, tension, comments)
✅ No rush, no tension-maxing. Just focus on consistency.
Months 2–3: Building Consistency​
  • 4–5 hours/day minimum
  • Gradually added tension using longer bars
  • Switched from cloth wrap to gauze wrap under the straps = comfort boost
  • Tried wearing it under loose pants while working from home ‍
By the end of Month 3, I started seeing noticeable stretch during warm-ups. Not full results yet, but it felt like my body was adapting.
Months 4–6: Real Progress​
  • 6+ hours/day regularly
  • Reached medium-high tension range
  • Took weekends off sometimes for rest
  • Introduced light massage + heat pad after sessions
  • Added 0.5 inch in measured stretched length (BPEL) by day 150
  • At day 180, my final gain was +0.9 inches in stretched length
⚠️ Warning: You MUST listen to your body. Over-tension or rushing = discomfort.
✍️How I Tracked Progress​
I built a basic spreadsheet to log:
  • Date
  • ⏱️ Session time
  • ⚙️ Tension level
  • Notes (comfort, irritation, pressure points)
Once a week I’d measure my stretched length — always at the same time of day, standing up, after a short warm-up.
It helped me stay motivated and made it feel like a real program instead of just “using a device.”
I recommend to buy Deluxe Limited Package with a 20% discount, because of the tension springs(4000g) and foam pads
Problems I Had (and Solved)​
  1. Strap pressure behind the head
    ✅ Solution: Switched to double-layer gauze wrap + adjusted positioning
  2. Slipping during longer sessions
    ✅ Solution: Cleaned silicone with warm water, dried skin fully, applied powder
  3. Fatigue after 5+ hours
    ✅ Solution: Broke daily use into 2–3 sessions (2h morning + 3h evening)
  4. Skin irritation after sweaty sessions
    ✅ Solution: Wipes + small dab of aloe gel after removing device
It’s not all sunshine — but everything is solvable if you stay patient and adjust.
Final Results at Day 180​
  • +0.9 inches in stretched length
  • +0.6 inches girth while flaccid (bonus!)
  • Better straightness and angle
  • More confidence overall
  • Routine feels like a habit now, not a chore
Honestly, I thought this was going to be some hyped-up gadget — but it turned out to be one of the most practical long-term tools I’ve ever tried.
✅ Pros & ❌ Cons​
Pros:
✅ Easy to assemble and adjust
✅ DSS strap system = best support I’ve tried
✅ Quality materials and durable frame
✅ Solid results with consistency
✅ Great for working from home or low-key daily use
✅ Backed by medical traction science
✅ Good support + guides
Cons:
❌ Not exactly invisible under tight clothes
❌ You NEED patience — results aren’t instant
❌ Skin conditioning and breaks are important to avoid irritation
❌ Measuring progress can get obsessive
Final Thoughts​
If you're serious about improving size or correcting curve without surgery or pills — this is honestly one of the best tools out there.
It takes commitment. But Quick Extender Pro gives you everything you need to succeed if you just show up daily and track your work.
Start with a reliable package (I recommend the Deluxe Edition like I got), and don’t skimp on comfort — it makes all the difference.
Here’s the official link where I bought mine with a 20% discount
If you’re dealing with curvature or Peyronie’s, they also have a full edition just for that.
If you’re thinking of starting, let me know — happy to answer questions or show you how I structured my logs. This thing really works if you respect the process.
Why I Chose Quick Extender Pro Instead of Penimaster PRO or Phallosan Forte​
When I was researching traction devices, I looked at everything — not just rod-based extenders like Quick Extender Pro, but also vacuum-based systems like Penimaster PRO and Phallosan Forte. All three have reputations for delivering real results, so I wanted to break down exactly why I ended up choosing Quick Extender Pro instead.
❓ Rod-Based vs. Vacuum Extenders – What’s the Difference?​
Quick Extender Pro uses a mechanical rod system with a dual-strap support (DSS) mechanism.
Penimaster PRO and Phallosan Forte use vacuum chambers that create suction around the glans and then apply traction using either a belt (Phallosan) or a rod or weight (Penimaster).
⚖️ Here’s What Made the Decision Clear for Me:​
FeatureQuick Extender ProPenimaster PROPhallosan Forte
Traction MechanismRods + DSS strapsVacuum + belt/rod/weightVacuum + belt
Max TensionUp to 4000g~1150g (belt), more with rod~2800g (belt)
Control & AdjustabilityPrecise, step-by-step tension controlLess control with beltTension adjusted by belt stretch
ComfortMemory foam + dual-strapSilicone chamber (can cause pressure)Bell sleeve can slip or cause suction fatigue
Curvature OptionYes (Peyronie’s Edition)YesYes
Daily UsabilityBest when seated or at homeBelt good for walking, rod for homeBest for long wear during passive activity
PriceFrom $119 to $349From ~$300+From ~$379+
DurabilitySteel rods + solid frameMixed (plastic + silicone)Mostly plastic and silicone
Why I Picked Quick Extender Pro​
  • More tension = more potential results
    I liked that the Quick Extender Pro Deluxe packages include tension springs up to 4000g, which is significantly more than what belt-based systems offer. That meant I could scale up over time instead of plateauing.
  • No vacuum fatigue
    I read a lot of user feedback saying that vacuum-style extenders (especially the belt versions) can cause blistering or suction pain after long hours. I wanted more controlled compression, and the DSS strap system worked better for that.
  • Better for active adjustments
    Rods allowed me to fine-tune the tension in small, measurable steps. With belts, it’s harder to measure how much tension you're actually applying.
  • Durability and replacement parts
    The QEP kit came with everything I needed: extra rods, memory foam, cleaning supplies, and a travel case. With Penimaster and Phallosan, it seemed like more pieces could wear out or need replacing (like the sleeves and valves).
Why I Skipped the Vacuum Devices (for Now)​
  • Phallosan Forte (link) is great for passive wear under clothing, but I didn’t feel comfortable wearing a belt system in public or at work. Also, it loses tension if you move around a lot.
  • Penimaster PRO (link) is more versatile, but switching between vacuum + rod or weight modes seemed more complex than I needed. I wanted a single setup and consistent use, not rotating components.
Also — many users say that vacuum systems are more forgiving for short wear times, but I was ready to commit to 4–6+ hours/day, and Quick Extender Pro gave me more control for those longer sessions.
My Final Thoughts After 6 Months​
If you’re sitting at a desk, working from home, or able to dedicate a few hours each day to real traction therapy — Quick Extender Pro gives you the best combination of adjustability, comfort, and actual force applied.
For me, it wasn’t just about convenience — it was about getting results, and I felt QEP gave me the best shot at that.
Would I ever try Phallosan or Penimaster? Maybe. But only after I’ve maxed out what I can do with QEP.
TL;DR:
Vacuum devices are solid but have limitations in traction force and control. If you're serious about structured gains and want something you can fine-tune and scale with, Quick Extender Pro was the right tool for me.
Let me know if anyone’s comparing them right now — happy to answer specific setup or comfort questions.
Here's the link I used to buy Quick Extender Pro with 20% off — I recommend the Deluxe Limited or Peyronie’s Edition if you want full support.
imanol555
458
SizeGenetics Extender - NO.1 BRAND - Best Selling Packages 2025​
sizegenetics official
male extender device
Below are the names of the packages available on SizeGenetics extender device.
  • Ultimate System
This is the recommended package as it includes all necessary parts and components.
  • Comfort Package
  • Value Edition
  • Curvature & Peyronie’s
sizegenetics official website
