Car was originally purchased from Jon Doward about 3 or 4 years ago.Was pretty much stripped as he was selling it for parts. It turned out to be in better condition than the one I had at the time.So I spent 3 years researching and buying parts as many of us on here.
ENGINE: INSTALL & REBUILD PERFORMED BY GRIP INDUSTRIES
1JZGTE- this engine was completely rebuilt w/all seals,gaskets,etc. replaced.
Replaced the turbos with the ones in the pic below.No shaft play and are running strong @ 14psi.
It has: JZA70R HARNESS(ORIGINALLY WAS SET UP FOR DIGI-DASH)
USDM 2JZGTE cams
Gray powder coated valve covers
NEW OEM VALVE COVER DECAL
3"DP W/y-pipe
HKS COLD AIR INTAKE
HKS dual exhaust
HKS SSQ BOV
HKS EGT
HKS BOOST GAUGE
HKS GAUGE CUPS
HKS OIL TEMP GAUGE (NOT YET INSTALLED)
JZA70 7K TACH
160 MPH SPEEDO
N/A VOLTMETER CONVERSION
FACTORY NEW GAUGE CLUSTER LENS
WALBRO 255 L.P.H. FUEL PUMP
VOODO MECHANICAL BOOST CONTROLLER
GODSPEED 4" INTERCOOLER W/ HARDPIPING
PERFECTLY RUNNING HYDROFAN ASSEMBLY
BATTERY RELOCATED TO REAR SPARE TIRE WELL
NEW OPTIMA REDTOP BATTERY
R154
STAGE 3 CLUTCH W/13lb. CHROMOLY FLYWHEEL
ARP flywheel bolts
NEW CLUTCH MASTER CYLINDER
3.92 REAR END
CAR HAS COLD A/C & HEATER/CLIMATE CONTROL WORK FLAWLESSLY
POWER STEERING WORKS GREAT
ABS HAS BEEN REMOVED (DIDN'T WANT TO WORRY ABOUT 20YR OLD UNIT GOING OUT)
BRAKES WORK FLAWLESSLY
STEREO NOT INSTALLED YET, JUST BECAUSE I LOVE LISTING TO THE ENGINE AND BOV
HAVE ONE I CAN THROW IN IF IT MAKES A DIFFERENCE.
BODY UPGRADES INCLUDE:
ENGINE BAY PAINTED GLOSS BLACK PROFFESSIONALLY
JDM DARK CHERRY TAIL LIGHTS
JDM TRIM '90+
JDM '90 SMOKED OEM TURN SIGNALS
KEVIN M REPLICA SIGNAL COVERS
JDM BUBBLE MARKERS
REMOVED REAR SIDE MARKERS
MKIV OEM FLOOR MATS (NOT THE CHEAP ONES IN PIC)
JDM ELECTRIC FOLDING MIRRORS (THAT WORK!)
90+ NOSE W/HEADLIGHT WASHERS INSTALLED ALONG WITH '88 BADGE
DEMON FRONT BUMPER
'89 CUSTOM HOOD W/ FUNCTIONAL SCOOP
NEW HOOD STRUTS
JDM MKIV RZ SUPRA STEERING WHEEL
SHORT SHIFTER MOD W/MOMO KNOB
NEW TARGA SEALS
ORIGINAL TARGA TOOL
SUSPENSION: (ALL NEW!!)
EIBACH LOWERING SPRINGS
TOKIKO ILLUMI 2'S
ANODIZED BLACK BILLET TEMS SPORT/NORMAL BUTTONS(THEY'LL NEVER FADE)
'92 TEMS ACTUATORS TO ALLOW FOR STRUT BARS
FRONT & REAR CUSCO STRUT BARS
NEW NYLON SUBFRAME SPACERS
MKIV REAR BRAKES, CAR STOPS ON A DIME, LOVE 'EM!
MKIII NEW ROTORS AND CALIPERS, PADS NEW ON BOTH SETS
SUPER ADVAN SA3'S 17"X10" REAR & 17"X9" FRONT
NEW FALKEN TIRES
PICS:
HERE ARE SOME PICS(ITEMS SHOWN NOT INSTALLED ARE JUST TO SHOW WHAT THEY WERE PRIOR TO INSTALL,THEY ARE THE ACTUAL PARTS)
I will add more pics soon.
USDM 2JZGTE cams
3"DP W/y-pipe
HKS COLD AIR INTAKE
HKS dual exhaust
HKS SSQ BOV
HKS EGT
HKS BOOST GAUGE
HKS GAUGE CUPS
JZA70 7K TACH
160 MPH SPEEDO
R154
ARP flywheel bolts
3.92 REAR END
JDM TRIM '90+
JDM BUBBLE MARKERS
DEMON FRONT BUMPER
NEW HOOD STRUTS
NEW TARGA SEALS
ORIGINAL TARGA TOOL
TOKIKO ILLUMI 2'S
NEW FALKEN TIRES
PICS:
