Well, might aswell share my project on this forum
This is a 86,5mod mkIII rebuildt to 7m-gte with manual trans.
My plan is to keep the good looking exterior as good as original and the interior aswell. The engine will get a total rebuild and the aim is to get my car running all day with 450-500 rwhp.
These are the parts iv bought so far, and will hopefully be part of my engine before summer 2011:
New OEM waterpump
New OEM Oilpump
Vi-pec V44 ECU
JE pistons 8,8:1 comp 83,5mm
Eagle H-beams std lenght
Brian Crower stg 2 cams
Turbo: Comp: CT458 Q-trim a/r.70
Fuel injectors: Precision 780
Titan Cam gears
ATI dampened crank pulley
Clutch ACT Ts2-xtg6
Valve springs: Comp 975
Greddy timingbelt
Moroso oil catch tank
Mishimoto oil cooler
2x12" cooling fans
Aftermarket boost gauge, oil preassure and temp gauge
Cometic gasket set
Cometic head gasket 1,6mm
supra mkIV in tank fuel pump
Custom made manifoil and downpipe
50mm WG
new dump valve
Greddy boost controller
HKS FCD
Precision cooler
JVTR alu radiator
All ARP studs and bolts
Clevite bearings
and so on..
I hope the engine will hold 450-500 rwhp for daily use :icon_bigg
well, this is a start anyways, and please feel free to give me advice as this is my first Supra build!
Thanks
Tom
New OEM waterpump
New OEM Oilpump
Vi-pec V44 ECU
Titan Cam gears
Clutch ACT Ts2-xtg6
Greddy timingbelt
2x12" cooling fans
Cometic gasket set
50mm WG
new dump valve
HKS FCD
Precision cooler
JVTR alu radiator
Clevite bearings
and so on..
Thanks
Tom
