My MK3 vs CBR600
Devin LeBlanc
1,830
Las Vegas NV.
Only got one video that was worth posting. Did about 7-8 pulls. This was one of the early ones, I was shifting to early and should have been starting in 2nd. End of night I was side by side and slightly pulling in 4th. 200lb passanger
1990
7MGTE Fully built race spec blueprinted
Stock Exhaust manifold
Stock Intake manifold
GT35R .82 @ 24lbs
1200CC Injectors
E85
Stock ECU
Lexus AFM
R154
ACT Extreme pressure plate
ACT 6 puck SOLID disc
2012 CBR 600
Power commander dyno tuned
Exhaust, ect
[video=youtube;O3RtL29mUVU]http://www.youtube.com/watch?v=O3RtL29mUVU[/video]
Devin LeBlanc
1,830
Las Vegas NV.
I'm running stock fuel pressure, idle and cruise AFRs are 15.0-15.5.
Im pulling airflow out down low and on cruise, and adding injector duty cycle in everywhere else. Pulling fuel on the air flow map adds timing and helps with spool and part throttle drivability.
Running my base timing at 8 degrees yields me 20-21 under boost. Pulling back o the airflow table also gives me more room before I hit fuel cut.
Shazzy
60
Texas
What are you using to pull airflow and change the injector duty, timing etc.? Piggyback? You don't have anything listed that's why I ask.
Suprapowaz!(2)
2,870
San Antonio, Tx.
And people say piggybacks are useless anything over 500rwhp. Or was it a ticking timebomb they said. Good job sir. If I had half the smarts as you do I'd get to it and tune with my MAP ECU. Of course I think my combo would only yeild me somewhere in the upper 400rwhp. What do you have your fuel pressure set at?
EDIT: Ok, I see you mentioned stock fuel pressure. But don't you have an AFPR??
te72
Classifieds Moderator
6,602
WHYoming
Guys, Devin is just a wizard, that's all. Don't try this on your 7m. :p
Devin LeBlanc
1,830
Las Vegas NV.
haha, Thanks guys.
Im running my fuel pressure at stock because thats what yields me the best part throttle and idle AFR with the 1200's and E85. Once in boost its 1:1.
