My little 7m truck went 9.4 @ the meet
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
intresting
the onyl big diff between my setup and yours is 550 for me for now an di run 9.3.1 comp
when does that thing spool
joliroger4
Flying Dutchman Pilot
Apr 4, 2005
264
New Jersey
www.geocities.com
No clue I only launch it off a transbrake which'll be totally different than your car rolling in 4th gear. On my two step and transbrake I see 15-16psi at 3700rpm.
My grey car has an identical 67 as well, but no FFI, OS valves or 4" dump pipe thats 18" long. I see the same boost on that by low 4000s. It really wasn't much different than my .70 p-trim 60-1. I think the exhaust wheel has the greatest influence and I've run nothing but P-trims the last 4 years so spoolup has been pretty much the same for me over all that time.
vas85
SupraNut
Sep 29, 2006
391
Sydney, AU
I saw that run on youtube when I just searched 7mgte very impressive run, shows the power of a 7MGTE is insane.
What hp is the motor at? :):)
NashMan
Aug 5, 2005
4,940
17
Victoria BC
44 psi in my rear tires on my rally car still have issue tring to spin them easyer yes they are over inflated but when you have poor powerd car what can you do
ther ment for 35 for over all temp
joliroger4
Apr 4, 2005
264
New Jersey
www.geocities.com
143 :)
75 shot. The car went 137 on all boost. the 143 trap only had 600lbs of bottle pressure. I didn't have a bottle heater so I couldn't get my pressure up. The heater is in now and I can get the proper pressure. I think the car has 147 traps in it on the bottle everything tuned right. I was also just blindly letting the transbrake go at no particular boost or rpm. I'll be back on my two step in the spring with a lot better ETs.
