So, been asked a few times and just responded to another...  so, I thought I'd show mine.  Of course it will vary for everyone... some things I already had on hand or even got for free (I will list the approximate cost anyways, for someone else to consider)...
2JZ, using auto tranny:
1. 1JZ motor mount brackets (have a set and borrowed another - free) ~$75
2. Custom driveshaft --- $420
3. 2JZ engine set ---- $2900
4. 12x24x4 Intercooler and misc pipes --- $350
5. 2JZ used US waterpump ($65), pulley ($20), & Fan ($65) -- $150
6. 2JZ TT powersteering line ($200...already had, but custom will cost $100) and throttle cable ($45) --- $150
7. Timing belt and misc belts/hoses --- $150
8. 7M oil pressure and water temp sender --- $25?
There may be more... just wanted to post it up and see if the other guys chime in with something I forgot. I had some things on hand and alot of things were cheaper. I went with an auto and custom driveshaft which added another $420 for the driveshaft and another $170 for an Apexi rev/speed meter (sent my 1JZ bellhousing to Cassio). Cost will vary by what you have and what extras you want... I'd say close to $5K, if you do the labor. It may cost you less, but you REALLY NEED to plan on $5K.
This is with you performing the labor and extending the harness yourself, etc.
Hope it helps some of you that are on the fence...
