My first time at the 1320..
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
So I went to the track for the first time tonight in the Supra. Actually it is my first time at the track in a rwd car ever. I went there hoping I could at least break into the 13's.
Car weighed 3635lbs. no weight reduction and 1/2 tank of gas.
First run was a 15.1
My fastest run of the night...
1/4----14.209 @ 99.71mph
1/8----9.2 @ 78.7
60'----2.224
R/T---.353
Then my clutch started slipping :( I put a little too much heat into it at the line one run and it never really recovered after that..Liked to slip on shifts to 2nd and 1st would take a few seconds to fully grab good. I guess its time for a new clutch. Also it liked to hit boost cut on quick shifts to 2nd.
Wouldnt spin the tires, just had a little wheel hop once if I didnt slip the clutch much.. I was shifting at about 5500rpm since my power was really falling off above that. Most of my runs were 14.5-14.7 all night.
It was still a pretty fun night.. I beat a couple of modded 5.0's, a modded 98 gt, and a 97 camaro SS auto..and of course an integra & civic running low 16's all night.
My mods-Are in my sig.
It was a cool night though so i was running at about 11psi on the stock ct.
I left the stock front swaybars hooked up as well.
-Stock intercooler pipes and IC...I think this is to blame for the power loss above 5k rpms.
Falken Ziex ze 912 tires.245/45/17 @ 40psi..I forgot to bring a tire gauge and air them down a bit but I dont think it mattered anyway,they didnt really slip.
I can't wait to go back with a driftmotion clutch and maybe a new IC and hardpipes!
Tun_x
Built to do the NASTY!!
Utah
nice work.. just get the clutch taken care of , put some slicks on and get it done
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Thanks. I was kind of dissappointed about not breaking 13's though. Next time I go i'll have a new clutch and intercooler so that shouldnt be a problem. I'll probably stick some drag radials on the ol' sawblades so i dont have to worry about skinnies. That and i have to drive it 30 mins to the track
gilberjj
Friend of Fast
Apr 14, 2006
661
Tacoma, WA
Even though it feels like the power falls off, with bpu mods, you should wind it out to redline. I bet you'll run a faster time.
One philosophy behind shifting at redline is during your shift (while you are coasting), you will be coasting at a faster rate, covering more ground, and at 99 mph, you might be able to wind out 3rd and save one extra shift.
Try it out and see what happens!
