My daily 2jz na-t
suprastupid
177
tx
Sent from my Droid using Tapatalk
suprastupid
177
tx
Have the wrong sump pan.Bit the bullet and just bought a REAR sump kit from driftmotion....
suprastupid
177
tx
Finally! Got some work done on the engine took some pics too! Lol. Got the old oilpan setup off swapped out the stock mains and rod bolts to arp hardware and our on my brand new oilpan setup sealed with good old toyota fipg. Bearings looked in great shape...bottom end...done. I also pulled everything off the head preparing for its removal, I am waiting on a stupid bit to remove the stock headbolts 34$ from snap on! Onto the pics!!
Before arp stuffs...forgot a after lol
Oh In trying to streamline my thread could a mod delete the posts I edited with a single letter?
Sent from my Xoom using Tapatalk
Nghty89
Zombie Chicks Are Hot
Mar 26, 2008
978
7 Cities, VA
$34 from snap on? Should just be a 14mm torx bit IIRC. Or around that size. Lol Pepboys ftw. I just bought a whole bunch of tools today to round out my collection. Good luck on that build, turns out I may need to bore my block, which means $500 for gte .20 over pistons from toyota, or aftermarket for higher. Or just buy a newer block and go get it for a third of the price and use my gte pistons I already have : p
Sent from my DROIDX using Tapatalk
suprastupid
177
tx
I tried a 10mm Allen and a t55 Torx and it felt like it was gonna slip.. I'm anxious to get the head off and make progress seen the bit set at oreillys for like 6$ and since my snapon bit wont be here till next Wed. I got it... head will be removed this weekend!
Oreilly bits.
suprastupid
177
tx
Head is off! It actually needed a 12mm tripple hex.It is at the machine shop for a check, valve job and cleaning, Should have it back in a couple days. I should have cleaned the deck before I did the oil pan swap now I gotta be extra careful, I got some rubber/plastic scrubber bits to remove the old material... one outta six of the spark plugs was a different heat rating.. thought that was weird and the water jackets on the block seem pretty clogged with rust deposits. Gonna need a healthy flush before the koyo rad goes in! Also there were some rubber pieces stuck in 2 of the coolant jackets, I got one out but one fell in, have no Idea what those are from. Here is some pics... Tell me what you think of the engine...good shape? or rehone/re-ring?
---------- Post added at 11:24 PM ---------- Previous post was at 11:22 PM ----------
Head
boxed
ready to go
valve seals
More soon!!
suprastupid
177
tx
Head is back.. full valve job and Res him cleaned up and perfectly flat. Block cleaned and checks out. Headgasket and head is on... sitting on studs not bolted, going to torque tomorrow.
Cleaned vs dirty
suprastupid
177
tx
Cleaned up this dirty bigger.
Pulled this guy out(front main)
Installed this guy but went in crooked and gouged it.. waiting for a OEM...whick is CHEAPER!
Waiting on a few parts to get it REALLY buttoned up but needed some motivation... I got it..
3inch ic piping as well...
mkiiichip
1,434
WI
Nice build so far.
Sticking with NA compression?
I see the 7m CPS, what EMS are you going to be using?
suprastupid
177
tx
Stock pistons and 1.3hg, using stinger ems rc 550s and is300 coils
suprastupid
177
tx
Mo parts from driftmotion!
Ant thing I should know bout installing the mk4 pump??
suprastupid
177
tx
Some quick pics.. I couldn't wait. Needed some visual motivation ..coilovers only installed on one side.. gonna do the other side on sunday.
I got the rear main in, flywheeln clutch assy. on and tranny mounted.I'm going to pull the 7m as soon as I can line up a powerwasher to borrow, then its 2j mounting time! Then wiring and finally acessories install..
