ok update time.  Like I said before.  All my resistances check out on the pins.  But no ticking when I shut the motor down.  I didnt detach it from the intake but separated the electronics from the base like I did when I cleaned it.  Sealing was not the issue as I was thinking.  I checked the valve per the TSRM with voltage and it does not function within parameters:biglaugh: .   Luckily for me I had a spare.  So I need to find another one for sale to have another spare.  So let me know if anyone has one for sale. :naughty:
Ok so I installed the other one. And fired it up!!
IT RUNS NORMAL!!!!!!!! That was THE problem.  So make note if anyone else has this problem.  This could be it.  And dont rely solely on the TSRM resistance measurements.  If it doesnt click to then it might be dead.  Thank you John and IJ, John, Dave, Jay, VIC(what is your name anyway?)  and everyone who has contributed to this thread whether it be technical help or motivation. All the help and kind words all kept me going and I thank everyone.
Im trying to be realistic as I know im still in the critical stages of this build.  I still have to break it in and keep an eye out for leaks and things.  And hope I dont have any codes pop up.  The idle is around 700 according to the factory tach.  I think its suppose to be around 650?  I'll have to watch that.
OH YEAH AND I DROVE IT FOR THE FIRST TIME.   Did I mention that??:naughty: It was awesome cause as you might not remember.  I bought this car not running.  So not is it just a first to drive my first rebuilt motor.  Its also a first to drive this car.  It feels strong but I havent layed into yet cause of the new clutch.  The tranny shifts smooth with the Red line fluids.  I just drove it down the street and back, but am leaving any more drive time to the break in.  I know the first 20 miles are critical and I have had to idle this thing to many minutes, diagnosing this problem, for my taste as it is.  I have to check the oil level and fix that PS leak and put the interior somewhat back together.  Maybe go ahead and wire up my gauges and then ITS ON!
Then bring it back and change the oil and check for leaks again.  Im running water in it right now cause I was expecting the worse and have to tear something down and didnt want to have to worry about draining coolant.  So I will have to drain the water and add coolant as well.
John should I go ahead and switch to the trasko at the first oil change or wait until the next?  I think you said at the first at the first oil change. Ill try to post some pics and maybe some video soon.  I want to try to take video of the break in.  Maybe with my 7 yr old manning the camera.  That ought to be interesting!!
