My 88' supra build QUESTION thread
trufanatic
THE FLYING TACO!
Apr 9, 2006
52
WPB FL
I still have alot to learn because the supra is a totally different beast than i've ever played with. Instead of making numerous threads asking questions taking up server space i'll just use this one.
So far this is what i have ordered and on my table.
Freshly machined and decked block with new thrust washer, standard bore
machined crank
ARP main studs
ARP head studs
ARP rods bolts
e-gay tubular t4 manifold
e-gay 50mm hks immitation wastegate with dump tube
nippon racing pistons with rings
eagle rods
king performance rod and main bearings
nippon OEM new oil pump
cometic head gasket
nippon OEM water pump
greddy emanage
greddy e-01
nippon new timing belt kit
egr block off cut outs
walbro 255lb fuel pump
FMIC -
Coming:
will figure out injectors when i decide on turbo
larger aftermarket radiator
suspension part: springs, shocks, strut tower bars, sway bars
FMIC piping and exhaust will be fabbed after car is completed.
Questions..:
Suggestions feel free, smart azz comments keep to urself
1. I need a sufficient sized turbo to attain 550whp, looking at t70, gt40, gt35r/gt40 wheel
2. Who makes cams for our cars
3. are adjustable cam gears worthwile for stock cams?
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
1: A gt35r would be perfect for your hp goals...
2: toda, hks, trd, schnieder...
3: no... from what I've read, heard, talked about, adjustable cams arent worth the money... BUT, the main reason people have suggested I shy away from them is because Im going with an AEM, so my timing will be controlled by that...
For 1 and 2, talk to Sean at Titan... :D
jdub
Feb 10, 2006
10,730
Valley of the Sun
trufanatic said:
Does boost come in slower on an automatic opposed to a stick?
Not with a 3000 + rpm stall :naughty:
An auto will keep the boost at peak as well...you won't lose rpm due to the shift. You can't out shift an auto...course driving ability helps a huge amount with a manual too. The 340E has to be built to take the higher HP numbers...it's expensive (in the $2500 range), so most guys go the manual route.
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Depends on the turbo you go with... You go with a GT series turbo, the wheels are different, more efficient, and cost more, but you can use a larger AR on the exhaust side and maintain a similar power curve... So if you go with a GT, get an 81, if not, then something smaller than a 70...
trufanatic
THE FLYING TACO!
Apr 9, 2006
52
WPB FL
I've made my list and im now checking it twice, alot of this crap is STILL in the mail.
Any suggestions for my bottom end from my list above i think im pretty much done there or am I????
For fuel, im doubling up with an intank Walbro 255 and an external 255 also.
trufanatic
THE FLYING TACO!
Apr 9, 2006
52
WPB FL
GT40 turbo, too big? or good enough for later improvement if i choose so?
Turbine Wheel: GT40
Exducer: 3.05"
Mayor : 3.46"
Compressor Wheel: GT series
Exducer: 2.56"
Mayor : 3.90"
A/R 1.05 Exducer
A/R 0.66
