My 4 Door Supra Build
wesbeech
Beech Performance Motorsports
Feb 26, 2006
1,022
Akron Ohio
Well i decided im not using the 350 track rotors im using my 13 inch will wood rotors i have with my cutom made rotor hats they are almost done i just have to put then in the cnc mill and scallop them inbetwen the mounting ponts but here are some pics.
Wllwood next to stock
Just the rotor
Test fitting in the wheel
The caliper sitting on the rotor
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Well today i got my new injector clips in.
Went ahead and dug these 2 books out.
So i can do this pain in my ass wiring for the swap.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Well here is what i got done tonight. I got the whole harness stripped and started removing wires and plugs im not using.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Well today i wired in my injector clips.
And i started to repair my o2 sensor plug cuz the plug was trash so i got one off an old harness i had. i had to cut all the wires about a foot back to get past the mesed up wires. When i realized one of the wires was sheilded. O well this week end i was gonn re wire my knock sensors tie bot wires toghter and run 2 sensors for my knock gauge. Ther for using all 3 knock sensor spots on the block. But i allready have to buy sheilded wire so whats another package of it right?
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Well my rear brakes came in today.
Well i made the turbo flange tonight.
I have started making my collecter.
I opend up the holes in my head flange to accept the 1 1/2 j bends so now all i need it to make my waste gate flanges and order my box of j bends then i can build my turbo manifold.
WOW.......I must be slacking. I love the new car and it's going to truly be the ultimate sleeper with the new turbo installed.........:bowdown:
I haven't read the whole thread yet. I'll try and do that tomorrow to see what sort of plans you have for it.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Ok you do that then reprot back to me. My dad has been yelling at me alot latley thats its a daily drive not to mess with it not to upgrade the brakes or this or that. Well he has a surprise coming spring time when i tell him i need to take a week of vacation time to do the swap and work on my car. :evil2:
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Well today i got 90% of the turbo manifold collecter done. I need to grind down the welds havent done that yet.
And the hole for the outlet to the wastegate
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Ok well today i set up my bbk and made the mock up brackets so i can get all the sizes right and mill the real ones out. So here are some pics of my big brake kit im making for the cressidas. it uses my custom made rotor hat willwood 13 inch drilled and sloted rotors and 300zx tt calipers.
Well what do you guys think?
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Well today i got my long runner intake manafold back that i made its almost done i have to make a wheel for the tb and cables and put a fitting and sensor on it then polish or paint it. What do you guys think?
It's coming along slowly but surely Wes. It must be nice to have machines like that any time you need them. Are you going to drill your manifold for some vacuum ports? I don't know how many you'll need, but it's looking good. What turbo are you going to be running with this setup?
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Yes its nice. And no im not drilling it for vac fittings there is a -6 bung above the icv to feed a vac manifold.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Well today i got alot of parts in
My new 6 puck ceramic clutch
My slightley used atc presure plate.
My new slave cyilnder
My 89 ecu witht the HAC sensor mod for the maft pro
My new maft pro.
My new knock gauge.
20 feet of sheilded wire to re wire knock sensors and for the gauge.
And my 3" stainless mufler
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Well today the 3" stainless came for my exhaust. Along with all the elbows.
I got my gates racing timing belt.
I picked up the other half of my oil filter relocation on sunday.
And i finshed my billet alternator puley.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Ok well i have got a few parts in latley. I got my front mount intercooler my piping kit for it my bradied stainless brake lines. Im still waiting on my caliper rebuild kit and a lot of ss o2 sensor bungs.
I know these pics wont shou up till sat but when they do you will like.
My 20 j bends to make a turbo manifold.
Only have used 9 of the bends so far but i still have to plumb the wastegate and dump. But the manifold took me 3 hours to fab up. What do you think?
Well thats all for now.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Well i just talking to my guy in dayton to confirm he can still ceramic coat my turbo manifold hots side and wastegate body. And he said were good on that so once i test fit everything were good for satin black ceramic coating.
