My 1.5jz
aphxero
787
Seattle, WA
Thanks to evolution for the bottom end some months ago.
Some pics and stuff:
Check out my sweet ebrake knob. Yes that's a dead baby turtle. Let the hate begin.
And vid:
http://s187.photobucket.com/albums/x302/apxhero/?action=view&current=cress-0.flv
Parts on car:
Jic flta2 for jzx81
Trd 2 way 4.3:1 in 4 bolt carrier
Spw type 4
Turtle brake
URAS rs exhaust
Weds sport sa70
R32 front brakes
SS brake lines
JDM polished door handles
81 MarkII trunk lock
4 point belts
New clutch pedal and hydros
Non abs brake lines
Equus 60mm boost gauge
Autometer street tach 3"
SAFCII black
HKS air filter
HKS turbo timer
29x12x3" FMIC
On order:
Kmac sways
Sparco seat
Sexy style aero
flipsidecustoms rear toe/camber arms
In shop:
Flex a lite heater
permacool fan (for sale!)
tourerV badge
Engine/mission:
JZX90/jzz30 wiring harness
ECU for said harness
rebuilt 2jzgte shortblock
resurfaced/valve seals 1jz TT head
machined 2jz cams
Non trac TB
USDM 550cc injectors
OEM 1jz gasket set
new 2jz oil pump
non hydrofan water pump
aluminum pulleys
ARP head studs
ARP flywheel bolts
DM tranny hardware
r154 trans rebuilt jza70 spec
HKS gd max clutch
HKS t4 turbo
T4 Chinamanifold
Tial 44mm WG
Still needed:
Driveshaft
Flipsidecustoms 6 point cage
SerialNine endlinks
SerialNine TC rods
Poly flca bushings
Poly rack bushings
aphxero
787
Seattle, WA
Thanks! Machine spec is as follows:
Parts on car:
Jic flta2 for jzx81
Spw type 4
Turtle brake
URAS rs exhaust
Weds sport sa70
R32 front brakes
SS brake lines
4 point belts
Non abs brake lines
SAFCII black
HKS air filter
HKS turbo timer
29x12x3" FMIC
On order:
Kmac sways
Sparco seat
Serialnine aero
In shop:
Flex a lite heater (when it gets cold out)
tourerV badge
Engine/mission:
machined 2jz cams
Non trac TB
OEM 1jz gasket set
new 2jz oil pump
aluminum pulleys
ARP head studs
ARP flywheel bolts
DM tranny hardware
DM aluminum driveshaft
HKS gd max clutch
HKS t4 turbo
T4 Chinamanifold
Tial 44mm WG
Still needed:
SerialNine endlinks
SerialNine TC rods
Poly flca bushings
Poly rack bushings
aphxero
787
Seattle, WA
haha 1.5jz is best with smallish turbo. good for response but a little slow up top. awesome for that drifting thing I do...
aphxero
787
Seattle, WA
Hey tom yeah this is a different car. I'm living in pdx now :)
Justin: Yeh cressida is a much lighter car and way more stealth. I had some probs on the dyno last night. Pretty sure this random miss is being caused by my 7m resister pack. I cant say for sure since I have no part to test with.
So all night long it made like 290-300 at 14 psi. Then the miss went away on one pull so it was the same shit until 6krpm then suddenly made over 400 for that little bit. I did it twice to make sure. Weird shit.
Even weirder is that the motor misses randomly but only when I plug in injector 6. When 6 is unplugged the motor runs evenly on 5 cylinders. If I plug 6 in and unplug others the car still misses. Then it gets weird. When I plug in a noid light instead of the 6 injector it causes the same random missing.
Crazy. If I can figure this out we're probably looking at 420whp at 14psi.
Oh and btw this thing made full boost at 3krpm :)
aphxero
787
Seattle, WA
So it turns out I wired one coilpack backwards. It probably didn't fire right until up top because the dwell was too much to fire it backwards. Makes sense.
Low boost for now. 370-380 with torque fucking everywhere. 350 ft lbs at 3500 rpm :)
Vids in a minute.
Pernilongo
LADA is my daily
Jul 15, 2007
446
Los Angeles
WOw awesome car dude. I had a supercharged Crown back in the day. that thing was so classy. this Cressida reminds me of it. I didn't know that Bride makes steering weels though.
You cut the video off when it was getting good...............:evil2:
Full boost at 3000rpm is insane. I think my gt35 doesn't make full boost (17psi) until 4800rpm. That's going to be one of the sleepiest sleepers of all time.
