MSD DIS 4 on 7m-gte....detail HELP!
gixxer750
2jzget comingsoon!
Mississippi
I'm thinking about buying a DIS4, because I do a good bit of drag racing.
What is involved in hooking this thing up? Yes, I did search, but found nothing 7m specific. Does this go before the ignitor or after...? How does it hook up...
Pro's, Cons?
Thanks in advance
RacerXJ220
Interdimensional
Abalama
The DIS-4 is your NEW ignitor. If you want to 2 step it, I'd recommend different coils. Stock ones having issues.
The GM replacements from Summit are cheap good replacements. MSD also has some good ones slightly superior, but same voltage.
Just FYI, this is what I've researched so far.
I've got the DIS-4 going onto my setup with the Stinger EMS, and I'll go with the aftermarket coils.
I just saw a very similar thread with nearly the same info.
gixxer750
2jzget comingsoon!
Mississippi
I'll probably get the msd coils....
I guess I'm kinda looking for a supra specific wiring diagram, because we have a "strange" ignition system.
figgie
Twin Cities, Minnesot-ah
forgo the DIS. If you just want a bump in voltage. Ditch the stock 7m coils and get some bosch racing inductance coils. Now the 7m coils are more than capabe. The only problem is the 14+ years of useage and deterioration on them. ;)
lintlars
ROOTS RADICALS
Ft.St.John BC
The directions supplied with the MSD work you will need 2 tach adapters and 3 MSD gm coils I have this setup in my car 2 step is also functional I hooked mine up as in figure 13 in supplied installation documents
