Mpeg Divx Encoding
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
Need some help to make a Vid File i have smaller so i can host it for people to see
I have tried Divx Converter but i keep getting Error 5090
Other then that i have no clue of what i can use to get this Video down in Size so it's easy for everyone to view
please help someone, this is a little out of my area of expertise
drunk_medic
7Ms are for Cressidas
Woodstock, GA
Here is what I always do:
Take the original and re-encode to MPEG using a program called TMPGENC. If you have problems with this process, the vid might have problems, period. Not un-fixable, but sometimes they need "massaging".
When you are done decoding, then use Dr. Divx or another divx encoding program.
It takes awhile, but decoding to MPG first usually helps me with problems.
drunk_medic
Woodstock, GA
I'll have to remember that.
The reason I use other programs is just because I am used to them and they are very customizeable. TMPGENC is extremely powerful if you know what you are doing. I often use it to resize a video and slow down the motion search accuracy and encoding speed. I also use it to re-encode wmv, asf, avi and other video to mpg so that I can use the MPG tools to cut out unnecessary crap, join and then re-encode.
Programs I use [depending on clip, sometimes I use combinations]:
TMPGENC
Vdub [I believe v1.3c is able to work asf/wmv]
ASFTools 3.1
Dr. Divx
Sometime I will use others, but these are the usual suspects.
