Mounting Engine on Stand
sathu
125
SJ, CA
Hey guys, I removed the engine during the weekend and now taken most of the stuff off and it's ready to get put on an engine stand but do you mount it in the front or the rear? What size bolt do I need to mount the engine, the one i have for the engine before this might be different since it's a honda engine.
sathu
125
SJ, CA
I would say the rear seal, the one that cover up the Crank Shaft where the flywheel is bolted to.
sathu
125
SJ, CA
How long was the bolt you use for the engine mount? Homedepot has them up to 80mm, Orchard Suply has them at 100 and 110. Should I go for the 100 or is that too long, I don't think they have 90.
