Motor gets stuck.
10secdream
Got Boost?
Sep 11, 2007
767
Edmonton, Alberta, Canada
Well I just finished completing my 1JZ single turbo swap and I was hoping to fire the engine today. I pulled the efi fuse so I could prime the turbo with oil and I went to turn the motor over. At first it sounded ok and it cranked for about a second or less and then it just stopped. The engine stopped as if there was something in the way.
I then turned over the engine by hand and it was harder then usual and I hear a squeaking noise coming from the bell housing area. It went away after a few degress of turning the motor.
I then tried to turn the motor over again and sometimes it will turn over continuously and other times it will just stop.
Any idea what this could be? I pulled the starter motor and all seems fine and I inspected the flywheel. I am beginning to think something is binding in my clutch perhaps?
10secdream
Got Boost?
Sep 11, 2007
767
Well I just checked it out and I decided to pull all my plugs first. What do you know cylinder 6 was filled with fuel which would explain the massive amounts of compression and the engine stopping at TDC. After I got the engine all cleared up she fired first shot. Only problem was it died and I could not restart due to my battery being dead.
hewhohateme
concord
thats bad luck...thats fate to work hard and get something done only to be stopped by something small.lol i'd have my lawnmower in there trying to jump it
