Has anyone considered replacing the CPS with an AEM Engine Position Module link below.
http://www.aemelectronics.com/engine-position-module-puck-universal-1283
I would think you could just remove all the sensors out of the cps and make a mounting bracket and coupling to connect the shaft from the stock cps to the the AEM sensor then just wire it into the harness. I would imagine and AME EMS would be compatible with this sensor you would just have to adjust the cam/crank settings. with this sensor being only $175 its a hell of a lot cheaper than a new cps sensor and probably more reliable.
anyone have any thought on this?
