MKiv transmission on a 7mg(t)e...do they bolt up?
Dirgle
Conjurer of Boost
Pauma Valley, CA
The only transmissions that directly bolt up is
r154 (7M bell housing)
w58 (7M bell housing)
a340 (7M bell housing)
There are versions of these transmissions on a few different motors, but they need the 7M bell housing to bolt up.
Now if you get in to custom bell housing adapter plates, custom drive shafts, and the other work sometimes needed to retrofit a tranny, then the sky is the limit. But that get into $$$$ and a lot of custom fabrication. Just look at IJ's thread to see all the work that went in to installing his Termec TKO/500 5 speed.
