So currently im using pre 89 square brackets with the pre 89 square rubber mounts in a 89 chassis. I can obviously feel the engine is not set 100% and would like to change them out before i hurt the drive train or exhaust.. My question is, to use mk4 motor mounts, do i need to get 89+ brackets? Or mk4 brackets? Or will the mounts simply bolt onto the pre89 brackets? Thank you.
