origionally posted by KirkMKIV:
Non-Turbo Specifications
Horsepower 200@6200
Torque 187
Weight 3400-3500
Engine 7M-GE 2954cc
Transmission W58
Injector Size 380cc
Spark Plugs NGK BCPR5EP-11
Compression 9.2:1
Cylinder Pressure 156
Fuel Pressure 33-40psi
Wheels 16x7 / 225-50-16
Turbo Specifications:
Horsepower 230@5600
Torque 245
Weight 3400-3500
Engine 7M-GTE 2954cc
Transmission R154
Boost 6.8psi
Turbo Toyota CT-26
Spark Plugs NGK BCPR6EP-N8
Injector Size 440cc
Compression 8.4:1
Cylinder Pressure 142
Fuel Shutoff 11.4-13.7psi
Intercooler Efficiency 3psi drop@6.8psi
Features:
ABS
Targa Sport Roof
Power sunroof (90-92)
Drivers Air Bag (90-92)
Ltd. Slip Diff.
Automatic Climate Control
Progressive Power Steering (89-92)
5 speed manual4 speed auto
Toyota
Electronically Modulated Suspension(TEMS)
8-way power
drivers seat
Tilt/Tele Wheel with memory
225/50R16 Tires
Headlight Sprayers
SuperMonitor
(86.5-88 for fuel tracking, maintenance, etc)
86.5-87Cloth or Leather Interiors
Cruise Control
Power mirrors with built in defroster
For those of you who are reading this going "Damn the turbo only added 30 horsepower???" Look @ the RPM where the horsepower is being made...its 230@5600RPMs on the turbo model while it takes the NA all the way up to 6200RPM's to produce 200..... Just a little fact.
Horsepower 200@6200
Torque 187
Weight 3400-3500
Engine 7M-GE 2954cc
Transmission W58
Injector Size 380cc
Compression 9.2:1
Horsepower 230@5600
Torque 245
Weight 3400-3500
Transmission R154
Boost 6.8psi
Turbo Toyota CT-26
Injector Size 440cc
Compression 8.4:1
Features:
ABS
Targa Sport Roof
Ltd. Slip Diff.
Toyota
8-way power
drivers seat
225/50R16 Tires
Headlight Sprayers
SuperMonitor
Cruise Control
