mk3 clutch master cylinder
CrazyInside
53
Oregon
I have a 91 supra i'm doing a 5 speed swap on and I need to get a CMC, my question is there a difference between the 86-90 and 91-92's? They look exactly the same in the picture but the 86-90 one is like 40 bucks and the 91-92 is over a 100. Am I missing something or can I just use the 86-90 on my 91?
The fitting on the line is different.
You would have to change the line and the master to the old style for it to work.
CrazyInside
53
Oregon
I'm buying a new clutch master witch are the same for all years.. and the single clutch line from driftmotion sense my auto care has no line. So that should work then?
You would need the early style master if your going with like the ss line from dm.
The 91/92 has a banjo fitting at the master while the early ones have a flare fitting.
Other wise the masters are the same.
