missing options with standalone
speedfreak
SCruzer
May 16, 2006
109
santa cruz, ca.
hey guys i recently pulled my wiring harness out of my 92 turbo supra m/t. running great on my sds em3-6f standalone, but ive lost power steering and heater:( power steering because its progressive power steering and heater just wont let hot water in. not too savvy on wiring diagrams thought maybe some of you could help. I just want some power steering not progressive and want my heater to function. need to defrost!!! let me know if yall can figure a way to bypass any electronics that can help me...
Pps is 2 wires from the connector on the rack to the body harness through the engine harness.
Heater just take the supplied vacuum hose(that comes from the manifold) that goes to the vsv and apply it straight to the valve. This will bypass the valve and you will have heat when ever you need it.
Both of these use the same connectors and are controlled separate from the engine Ecu. They are just ran through the engine harness. Should be pretty easy to find at a junk yard.
