Might need an alternator
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
maybe you need a better wire from alt to battery, and ground... those were my reasons for low voltmeter readings (would flux between 11v and 14)
NYsBlueMA
Evo+supra=3 cars
Sep 24, 2009
136
New York, New York, United States
Mine bounces but it stays at 12 mostly like it just wiggles above or below I heard something about a MR-2 alternator would bolt up and its stronger but I dont think my old 7MGE one will fit
NYsBlueMA
Evo+supra=3 cars
Sep 24, 2009
136
Hey guys I got a serious problem changed my alternator and battery drove down to my cousins thinking that would fix my charging problem. When I went to go start the car I did nothing but stare back at me with dim lights. still have a battery light on, car isnt charging and I put in brand new parts this charging problem could also be why my tps doesnt go past 2500 any info on the alternator wiring would be a big help
JonoTurbo
Going for broke
CT
Check your ALT fusible link & fuses. Also make sure the main power wire from the alternator is still connected up, since you have to extend it in the 1jz swap it might have disconnected somewhere.
NYsBlueMA
Evo+supra=3 cars
Sep 24, 2009
136
Checked all fuses continuity the whole 9 nothing all these tests and nothing then snowball to the face made me realize the alternator stud is straight to the battery grounded to the casing hit it with the test light nothing then I realized I only have the cable to the starter and grounds on where does the alternator wire come from off the harness?
Ooh you may begin laughing I did :biglaugh:
JonoTurbo
Going for broke
CT
The stud on the alternator connects up to the harness where the original 7m alternator connected over by the battery. If you haven't done it yet, you'll have to extend that wire across the engine bay to the other side to hook it up.
NYsBlueMA
Evo+supra=3 cars
Sep 24, 2009
136
so on the 1JZ harness does it poke out at the front middle or rear of the intake manifold I want to find the other end first so when i pull it through the new wire will follow and I just have to join it to the original alternator wire, so I need to find giant crimpers
JonoTurbo
Going for broke
CT
It doesn't actually go very far into the harness... if you follow the wire it just goes into the harness for a few inches and then comes back out on the passenger side. Its supposed to connect to another wire in that area behind the passenger headlight and then run under the radiator support to the drivers side. So you have to run a new wire, there's no wire there already.
JonoTurbo
Going for broke
CT
Run it to the old alternator wire, i'm not sure what connecting it straight to the battery might do.
NYsBlueMA
Evo+supra=3 cars
Sep 24, 2009
136
turboguy327;1476966 said:
You can safely run a power cable from the alternator B+ to the battery B+ without hurting anything. It will actually help you rather than hurt you.
Well i was afraid the battery might overcharge and pop I bolted the old 7M and the new wire together and tapped it from there to the alternator works fine charging at like 17v lol
