This is for the people who are looking to turbo their NA engine. This will sort of be a how to or at least how I did it. I had a turbo setup with a RRFPR and it never really ran well at all so I changed just about everything.
It is a pretty cheap setup in terms of cost but it is a full standalone setup. It was a pretty easy and straight forward install. Easier than even a PNP AEM on a 7mgte because of the multiplex crap that never seems to work right.
This guide was made for the 5mge but it might help someone with a 7mge or even a 2jzge.
I dont know the 7mge or 2jz ignition system but from what I have read similar to the late model 5mge.
[video=youtube;Vz6ipbeF9Us]https://www.youtube.com/watch?v=Vz6ipbeF9Us[/video]
Factory Service Repair Manual(TSRM)
MKIII
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/default.aspx
MKII
http://www.cygnusx1.net/Supra/Library/TSRM/MK2
Main parts
4 wire stock TPS Make sure the TPS works. Mine did not work so I pulled all apart and it seems like the ceramic solder points dont hold and it loses connection inside.
Stock coolant temp sensor
Stock ignition setup with stock VR pickups(2 of them)
$30~ GM 3 Bar map sensor
$20~ GM IAT(Any IAT should work I use a buick GNX)
$210+ 750cc high impedance injectors bosch style
$120~ Walbro 450 in tank pump
Stock fuel lines/rail/FPR
$360~ ECU is a Microsquirt V3 with the 8 foot harness yes Microsquirt
CT26 with 7mgte exhaust manifold
$50-$150~ Oil feed and return lines soft line kit works the best(rabidchimp, arizona performance, drift motion, ebay ect)
Return bung welded oil pan
$50-$350~ 2.5 inch IC pipes with matching IC diameter(can be same side exit or normal or even stock 7mgte stuff)
IAC removed and blocked on intake
EGR blocked on intake manifold and head/exhaust side
$125~ Wideband O2 sensor I use the LC-1 but a cheaper one is the Spartan V2 from 14point7 which should be fine
Downpipe with O2 bung
Turbo to airfilter pipe(accordion pipe)
Colder spark plugs I used NGK BRP8ES
This runs $1100~ plus whatever it costs you for the parts that dont have prices next to them.
Recommend/optional parts
Oil filter relocation kit(cant replace filter without pulling turbo without this)
Stronger clutch if running more than 5psi or sticky tires mine was new and slipped
2JZGE w58 6 puck clutch worked for me
Bigger radiator with electric fans( I use a MKIII aluminium one off ebay)
Microsquirt ECU is basically Megasquirt V2 with some unique features and some missing features
The V3 version is important here because it has dual spark. Update to firmware version to MS2/Extra 3.3.3
It does not have stepper motor control so it cant run the stock IAC but if you want an IAC you can get a PWM valve.
Fuel setup
Drop the tank and install the walbro fuel pump in the stock pickup
Install the injectors into the stock fuel rail.
Replace the fuel filter
You can run any size injector you want I just chose the 750cc because I plan to run e85 at 15psi of boost
Just make sure whatever injector you run is high impedance OR you have resistors installed inline as the ECU cant run more than 2 if low impedance.
Also check your injectors before you install them one of mine was stuck wide open and flowed full flow of gas directly into the intake manifold filling nearly
the entire engine with fuel
Fuel injector wiring makes this batch injection the microsquirt does not have enough outputs to run sequential injection
The injectors and ECU need to run off the same 12v relay
You should solder and heatwrap all connection you make if possible
The stock fuel pump relay is triggered off a wire that normally runs off the stock AFM
You can wire this as shown in the images to have it run off key on
Wiring
Begin by removing the entire stock engine harness and ECU. The harness will pull through the firewall without needing to cut anything off.
Cut the TPS and coolant sensor connectors off you will be reusing them.
Wire using the diagram below and the microsquirt website here
http://www.microsquirt.info/uswiring.htm
All of the wires on the harness that comes with the ECU is labeled
You need a switched 12v power supply from a relay for the ECU and injectors
Turbo/charge piping
Trim the exhaust manifold to clear the power steering bracket a grinder worked for me.
Pull the oil pan and get a bung welded to it. I suggest a -10 AN bung for the drain.
The block has a oil port on it which is BSP thread use that for the feed. You can buy BSP to -4 AN if you are using AN
Double check the wastegate is working and install the turbo make sure you have gaskets where needed.
Routing the intercooler pipes can be a pain and is up to you how you want them routed.
I suggest using T-bolt clamps for everything if you can
The charge piping needs to flex a bit as the engine moves side to side under loads.
Install the downpipe I would not recommend a stock MKIII one
You can get a nice elbow and get a downpipe/exhaust made at a shop for pretty cheap as well.
Wiring diagrams
Tune setup
Calibrate your TPS
Setup for your wideband and map you are using in the settings
Input the general settings and the basic tune settings.
ECU needs power when you burn the settings to it.
Also needs a reset(power off and back on) for some settings after you burn them.
Most important part to get your timing correct
On the ignition options menu the tooth angle will need to be adjusted
IT WILL NOT BE THE SAME AS SHOWN
For example on my setup I had to set the dizzy a tooth retarded to get it to zero out base timing
It might need to be 0 degrees or 30 degrees on your setup for the tooth angle number 1 setting
To set this correctly you need to set the fixed advance option to Fixed Timing
Using a timing light on the crank while the car is running, adjust the tooth #1 angle to get the timing to match exactly timing for fixed advance setting
I used 0 for the fixed advance setting and had to set the tooth #1 angle to 9 degrees
If it does not match going down to 0 on the setting you might need to retard or advance the distributor or even jump a tooth on it.
My car would start on rising edge setting but it would lose sync all the time at higher RPM
Falling edge cured that but it changes the timing by around 22 degrees
It is very important to make sure the ECU sees exactly the same timing as the engine is running at
This is a rough tune I made using some of the other tunes posted on here for the 7mgte like williamb82's tune in the megasquirt thread
I have driven this tune approximately 50 miles. Its a pretty safe tune I feel, AFRs run low 11s to low 10s at high rpm on boost
I have only ran 145kpa on this tune and have adjusted it a ton from what is shown but it will still work as a startup.
You can tune and adjust settings while driving you dont need to reset the ECU for every adjustment
ECU will show 1 sync loss every time you burn the ECU if engine is running.
I have swapped to E85 and adjusted the tune accordingly and it runs pretty good not even on the stock ignition.
YOUR TUNE WILL ALWAYS BE DIFFERENT FROM SOMEONE ELSES EVEN IF SETUP IS THE SAME CONSIDER THIS A STARTUP TUNE
If you are running a 7mge or 2jzge the ignition input settings might be different.
Images for the tune below are my first startup tune that I ran around 6psi on a 5mge
It should be pretty safe even on a 3.0L engine but watch your afrs and timing while tuning.
I suggest running race gas if you are on a turbo setup just for the tuning stages to be safe.
http://imgur.com/a/liENm
Direct Link to the MSQ tune
right click save as
Make sure the file ends in .msq
not .txt
http://www.geniusvr.com/1985_Supra_microsquirt/1985_supra_tune.msq
Main forum for the MSEXTRA if you have issues with the software or anything else with the microsquirt
http://www.msextra.com/forums/viewforum.php?f=101&sid=758a668d19d9e09ce765eb1c7ecfc2d8
MKIII
MKII
Main parts
Fuel setup
Wiring
Turbo/charge piping
Wiring diagrams
Tune setup
Calibrate your TPS
right click save as
not .txt
