Megasquirt thread: Megasquirt and You
No not all low imp injectors are peak and hold.
Check with fic and see if your are in fact peak and hold. If there not you will just need resistors.
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
This is the diagram I used when wiring mine
This way it uses the stock efi fuze
Jay C
283
Omaha, NE
Thanks hvyman I'll check with them. I know they are 3.2 ohms and they were flow tested saturated with a resistor. I wonder what size resistor I will need. I'll also have to find one that doesn't get too hot (which can be an issue).
Jdmfreak thanks for the info I'll print it out for when I am ready.
You will need about an 11ohm resistor. Megasquirt like resistance values of about 12-16 ohm iirc.
Wiring a resistor pack is the same thing except its in a box you have to mount. Just put a resistor inline on the ground side of the wire and it will do the same thing.
Jay C
283
Omaha, NE
Just received my stuff from diyautotune. I will start doing the wiring in the next week or two. Oh and at least on the ms3 pro the cam wire is shielded jusr like the crank wire.
