Measuring How much was Taken Off Block and Head
JT87NA
SLC, UT
How would I measure how much has been taken off my block and head? I searched through the TSRM and can't find the procedue.
JT: With any luck my new head will be here today so I'll be able to give you that measurement, as for the block not sure if I've ever seen specs for deck height! (Usually measured from the Main bearing saddle to the deck)
JT87NA
SLC, UT
Someone said it was 235.00 mm from the middle of the crank or something like that, what type of measurement tools would I need to measure both the head and block?
JT87NA
SLC, UT
People are telling me I need to get the head CC'd. What does that mean. Sorry for all the questions, newb to rebuilding an engine.
You seal a piece of perspex to the head over the combustion chamber with a small hole in the middle then fill it from a graduated container to find out how much it holds.
7m's I believe are 40cc chambers.
No probs with the newb questions it's better to ask!
