max boost
robbo185
693
Chicago
most people say 10-12 psi after a headgasket retorque
but if you have no supporting mods, i wouldnt turn up the boost
koulee
497
if you have no supporting mods, like he said, then 11-12 psi is when you'll hit fuel cut too.
Boss302
249
Mobile, Al
max boost is simply what the turbo and engine can handle and what it's set at. if you set boost at 12lbs. and hit that you've hit max boost.
88supraTT
292
around the bend
should search but i think this is a good spot to post.
if i were to by a 60-1 ct26 and just bolt it in and dive it. will i have to upgrade the injectors i am planning on buying 550s in the very near future.but i was just wounding if i could do it on stock boost.
Boss302
249
Mobile, Al
don't forget the walboro :icon_bigg yeah you should be fine but it would be the same as turning up the boost on the ct. by that i mean the air that is flowed.
ma70t
7mgte-s
Jun 7, 2005
141
va
im running 11 psi on stock fuel system on a ct 26 62-1 for about 1 halft year
now runs strong
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
hydro_yang said:
whats max boost i can go all stock that is safe!!!!!
why does one need five exclamation points on a sentence that is a question!!!!!(?)
Wills7MGTE
( . )( . )'s RULE!!!!
May 12, 2006
1,077
Jackson, MO
Well if your turning boost up on a car with stock DP and exhaust system, you're crazy, that extra thermal load of more boost on the turbo is gonna be too much for that exhaust and somthings gonna give.
