Math problem
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
I took a math test today, here was the bonus question:
Solve for Q & R (a real number)
(x+4)/(x+1)(x+2)=(Q/x+1)+(R/x+2)
Anyone know how to solve this? Actual numerical values btw, with no variables in them. Good Luck
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
You need to get it into a system....
**EDIT
From the start....
Multiply the entire equation by (x+1)(x+2) resulting in
x+4 = Q(x+2) + R(x+1) and then distributing...
x+4 = Qx + Q2 + Rx +R
**END OF EDIT
Qx + Rx = x => Q + R = 1
2Q + R = 4
now solve using a matrix or just substitution... Or just look at it until you figure it out ;)
Q = 3, R = -1
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
How did you break apart 2Q+Qx+Rx+R=x+4? We haven't learned that yet. Btw, your solution doesn't work. R would have to be -2 if Q=3. And wouldn't there still be an infinite number of solutions? Assuming breaking down 2Q+Qx+Rx+R=x+4 in the way you did it is possible, there isn't a limit to the number of solutions. In the equation you made, 2Q+R=4, Q could be 50, R would just have to be -96
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
His answer is wrong, but the process is right. you can take 2Q+Qx+Rx+R=x+4, and turn it into 2 equations.
factor together all of the X terms, and all of the non-x terms.
Qx + Rx = x
2Q + R = 4
What you end up with is Q+R=1, and 2Q+R=4
Then he put them into a matrix, and reduced it.
1 1 1
2 1 4
1 1 1
1 0 3
0 1 -2
1 0 3
So Q is 3, R is -2
Or if you don't understand matricies, you can use a system of equations.
SupraDerk
The Backseat Flyer
Sep 17, 2005
546
Tallahassee
**EDIT
From the start....
**END OF EDIT
2Q + R = 4
Q = 3, R = -1
I think your R is wrong.
You can use the Heaviside cover up method to solve this. It looks like a partial fraction expansion... so
evaluate the left hand side where the x+2 = 0 (x=-2) to get your R
(-2+4)/(-2+1) = -2 = R
now find Q
evaluate the left hand side where the x+1 = 0 (x=-1) to get your Q
(-1+4)/(-1+2) = 3 = Q
(x+4)/(x+1)(x+2)=(3/x+1)+(-2/x+2)
X = 1 ... 5/(2*3)= 5/6
(3/2) - (2/3) = 5/6
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
now find Q
(3/2) - (2/3) = 5/6
Ya, my bad. I didn't go back to check it. And I was too lazy to make the matrices in my calc, so I just eye-balled it. R is obviously -2, I was hallucinating.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
Haha, ok so that could easily be done by hand like you did, but I bet I could enter it in my calc before you could do it by hand.
I spent a semester doing matrices in Diff Eq so I'm pretty quick now. I bet I could do it with my eyes closed.
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
now find Q
(3/2) - (2/3) = 5/6
Can you explain that better? We haven't covered that in my class... :(
SupraDerk
The Backseat Flyer
Sep 17, 2005
546
Tallahassee
This place does a pretty decent job of explaining and showing:
http://cnx.org/content/m2111/latest/
Are you in Calc 2? If so, then you'll probably get penalized for using this method as they usually want to make you go the long ass route so you can see what's going on.
I learned this method in my Signals and Linear Systems class, at that point the professor was only interested in helping us get to our answer as fast as possible
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
Thanks, that's pretty damn sweet actually. I'm in high school (H) Algebra II, so I'm pretty sure this question was way out of our league, but I learned how to do it so its all good. Thanks guys
