Im planning on maxing out this turbo in the future. what size exhaust will i need?
C Cya New Member Aug 12, 2005 628 0 0 43 Columbia, S.C> Mar 3, 2008 #1 Im planning on maxing out this turbo in the future. what size exhaust will i need?
werewolves182 is without a supra :( Aug 23, 2005 436 0 16 Crownsville, MD Mar 3, 2008 #2 Wow, this question is way too open ended. For starters, What are your power goals? Will this be a drag or street setup? DD? Supporting mods? T3 or T4? For a street setup, I would run a .68 or .70 T4 AR or a .81 ish T3. The 1JZ seems to spool those sizes very well.
Jostar AEM powered 1JZGTE!!! May 21, 2007 746 0 0 45 Chicago Mar 3, 2008 #3 0.68 Ar should be fine, Some guy in the other forum made 665hp at 28 psi, with this turbo, i'm planning on running it too in the future.
C Cya New Member Aug 12, 2005 628 0 0 43 Columbia, S.C> Mar 4, 2008 #4 I should rephrase the question. Will a 3" exhaust be enough for this turbo at its max w/ a .68 housing? I want to do the exhaust only once.
K Krister Holset lover May 2, 2005 159 0 0 45 Finland, Europe Mar 4, 2008 #5 Bigger never hurts: http://www.supraforums.com/forum/showthread.php?t=478679
Jostar AEM powered 1JZGTE!!! May 21, 2007 746 0 0 45 Chicago Mar 8, 2008 #6 Cya;944124 said: I should rephrase the question. Will a 3" exhaust be enough for this turbo at its max w/ a .68 housing? I want to do the exhaust only once. Click to expand... You will be ok, My friend runs the same turbo & made 702hp at 32 psi on his evo 2, He has run a best of 10.24 at 145 mph...:aigo:
