master power t70 exahust sizing help
werewolves182
is without a supra :(
Aug 23, 2005
436
Crownsville, MD
Wow, this question is way too open ended. For starters, What are your power goals? Will this be a drag or street setup? DD? Supporting mods? T3 or T4?
For a street setup, I would run a .68 or .70 T4 AR or a .81 ish T3. The 1JZ seems to spool those sizes very well.
Jostar
AEM powered 1JZGTE!!!
May 21, 2007
746
Chicago
0.68 Ar should be fine, Some guy in the other forum made 665hp at 28 psi, with this turbo, i'm planning on running it too in the future.
Cya
628
Columbia, S.C>
I should rephrase the question. Will a 3" exhaust be enough for this turbo at its max w/ a .68 housing? I want to do the exhaust only once.
Jostar
May 21, 2007
746
Chicago
You will be ok, My friend runs the same turbo & made 702hp at 32 psi on his evo 2, He has run a best of 10.24 at 145 mph...:aigo:
