map ecu
rakkasan
Currahee!!
Fort Campbell, KY
miggles said:
how does this compare to maft pro's, looks similar but no digital readout or oxy sensor tuning.
http://www.performancemotorresearch.co.nz/index.html
It depends on your end goal. If you're only looking to ditch the AFM, MAP ECU would be a viable option. If you might be looking for more later, such as timing monitoring (and hopefully timing too), wide band intergration, boost controller, data logging, ect, then MAFT Pro would be the better solution.
HTH
miggles
i wasnt speeding officer
Jun 3, 2005
526
perth West Australia
im looking to get rid of the pesky karmen vortex and go with maft pro, seen this and its pretty much the same to me in the fact you can get rid of the afm and run a map. The fact there is a distributor in aust helps a little more though i prefer a maft as i can always search/ask for advise on this forum.
miggles
Jun 3, 2005
526
cheers for that drjonez, there is some interest in the aussie forums about the maft pro and there is a hint of a group buy though its just a EOI atm.
