Manual Wiring Harness with Automatic ECU
jd20phill
104
Little Rock, Arkansas, United States
This is in a 1990 Turbo with five speed swap. The car has the automatic wiring harness (with reverse and neutral switch wired up) and ecu. Im about to purchase a new harness from Toyota, and was wondering if a manual harness would work.
Halsupramk3
444
Mississippi
if you are going to a 5 speed from a auto then yes you have to have a 5 speed harness. it will have the correct sensor hook ups for the trans. i assume you have the correct speed sensor on hte trans.
jd20phill
104
Sorry i was unclear. i have already converted the car from an auto to a 5 speed with all of the wiring associated with this swap. im looking to buy a new harness and was wondering if i could use a 5 speed harness in place of my auto harness with the auto ecu.
Halsupramk3
444
Mississippi
ah then yes. the auto ecu will work with a 5 speed and 5 speed harness. the 5 speed ecu wont work with an auto car. the 5 speed tran you have and harness just wont use some of the auto ecu's functions but otherwise it will work.
akito
Keep Laughing.You're Next
Jul 31, 2006
1,568
Springfield/Va
What about if i have a NA auto and swapping a 7mgte in it. Would the auto turbo harness work with the NA auto trans?
akito
Jul 31, 2006
1,568
Springfield/Va
im doing a motorswap, keeping the NA auto trans. So i was just wondering if the harness for a auto turbo would work on a auto NA tran
akito
Jul 31, 2006
1,568
Springfield/Va
I am trying to find a turbo trans. All i want to know if it would just work. So i guess the engine harness will not work??? Anyone can chime in?
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
mine worked but i also used the sensors from my old turbo trans =/ i had a JDM trans (60$ woot) and the speedo was on the other side. but after swapping the rear section it worked out fine.
jd20phill
104
sorry to bring this back up, but before i spend 600$ on a manual harness i need complete clarification :aigo:. Will there be anything i need to do to bypass the neutral start switch since i will still be using the auto ecu or will it be just plug and play?
Halsupramk3
444
Mississippi
i dont think that will be a problem. the auto ecu will work on a 5 speed car. the nuetral start switch for the 5 speed is in the clutch petal and it may be wired into the same pin on the 5 speed as it is for the auto ecu.
i think at one time i used an auto ecu on my 90T 5 speed and no problems. i just dont call specifically it was so long ago.
