manual boost controlelrs
macsupra76
128
Calgary AB
there okay, i had one, it was fine, later developed a vacume leak, i guess you get what u payed for. electronic ones are the best if you got the cash money.
adjust the pressure very slowly!!!
Disced
Pie + NYQuil = FTW
Edmonds, Wa
I run one as well.. Always hits perfect boost... Grim is right on the expensive part... if you can afford it; go for the ebc but the MBC will do what you want... just make sure it is 3 inches on either side of the connector... or else it won't work efficiently.
