manifold upgrades for ct26
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Every once in a blue moon you'll someone selling a cheap handmade tubular exhaust on ebay for a CT-26, but I wouldn't trust it. Contact Greg at suprasport.com, he's suppost to be making an exhaust manifold out of the same process he makes his turbo elbows, a few months ago when I talked to him about he said that he'd eventually finish it off, but it was going to be about another 6 months... Maybe if a group of us expressed our interest in his manifold (I know for a fact that his work is the shit) he would speed it up and complete it and maybe do a group buy on it.
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
In reality isn't the stock Mani good enough to push even a upgraded CT26 to the limit?
I have a hard time seeing how this can worth the money really.
oscolivar1
Supraism
Feb 8, 2006
1,000
Virginia beach
Yes, People put down big numbers with the Boss, JT, and other bolt on turbo's. Porting it though would be ideal for 400+ imo.
s383mmber1
3,614
Somers New York
IIRC MK3Brent pushed WELL over the 450 mark on stock manifold with a boss turbo.
I think others have hit 500's with the stock manifold. Ported obviously.
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
so I think the question becomes is there any reason to upgrade the manifold if all you are going to run is a CT26?
and I think that answer would be: NO unless you wanted to get every bit of HP you could from a CT26.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
The only reason I would get a better manifold is if I was running a BOSS turbo or something similar that way I can make sure the turbo is getting the most exhaust gasses as fast, straight, and even as possible (which I do plan on using a BOSS turbo after break in ;)).
MRSUPRA
838
Maryland
I wouldn't bother with any kind of upgraded manifold wile still using the CT-26. The tiny turbine housing is going to be your bottleneck anyway. Just a waste of time, effort and money IMO for very little gain.
bluepearl
326
pa.
starscream5000 said:
Go out, buy a dremel, or cheap alternative, gasket match the runners, and gasket match the turbo flange area of the mani, done.
DO NOT gasket match the runners on a stock intake manifold.
