Making an engine harness myself
odomd
computer illiterate
Jan 11, 2006
130
nj
Hey man, I agree with you 100%. Do the wiring yourself. It is more gratifying to do it yourself. A multimeter and wireing diagrams,Thats it,oh yea and the want to. I have most of a 7m harness(plugs) if you want free.
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
Man if you look at the harness all opened up, its nothing mote than pieces of wire - a plug at one end, and or the other as well.
As long as the pins are correct, the plugs are done right, I don't see anything hard about it. ( yes I have done enough wiring to know )
I think its great you are tackling this on your own man. If you can work on airplane wirings - which requires you to stick to strict specifications - , doing a car wiring should be a piece of cake....The hours spent on it may not be though...
Do it.
crazysupra2JZ
740
Georgia
abustiffy said:
Start a project thread now, so we can ridicule you if you fail and praise you if you succeed.
i already have..and my swap is complete. doesn't look like i'll be getting any wire from work, supervisor didn't like the sound of what i was planning to do with it.
suprastanger507mgte
Hayward , Ca
Ric said:
If you can't even afford to buy wire yourself, you own the wrong car dude.
He did not say he could not afford it. The aircraft quality is what he said he would like to use....I want to see him succeed. Stop being a crab in a bucket and try to pull this guy down ....... :biglaugh:
drunk_medic
7Ms are for Cressidas
Woodstock, GA
crazysupra2JZ said:
i'm more or less...ok with wiring and following diagrams and such... so i can make a high quality engine harness, that will have stronger connections so they don't pull out of the plug. wires can also withstand more heat and are treated against corrosion.
anyone ever try this?
That's funny. I've undone many parts of the 2JZ harness, and it's easy to get pins out of the ECU side after you know that you are doing. You need to pop the yellow part of the plug off and use a small jeweler's flathead screwdriver. The pins/receptacles don't just slip out unless you trigger the right pin release area, trust me - and the ECU pins were the easier ones to get out than any others in the harness that I can think of.
As for the rest of the plugs, they can be a pain. You have to use a jeweler's flathead to semi-gently and patiently push the weather seal/gasket from around the plugs. This usually allows you access to some sort of main locking mechanism. Then you have to find out where to lift in order to release each individual pin. As far as quality goes, the Toyota harnesses are excellent. If you want to make your own, go ahead. If it were me, I would extend a harness or buy one, but I wouldn't build my own, and I love to solder.
GeneStarWindGSW
Been To The Other Side...
Mar 25, 2007
992
No Man's Land
www.bidmingle.com
well have fun man doing that harness , but if i was you i'd save myself some money & buy this instead ;).
it has a wiring harness done it in already.
http://www.supramania.com/forums/showthread.php?t=47813
