Purpose:
I wanted to make this thread as a concept idea, and for brain-storming. This is an idea that I have been formulating for some time now. Please throw ideas out to me, but when you do please have a good basis and use factual information on your idea. Before I create a build thread of any sort, I want to make I have a good plan for my motor.
Goal:
To have my MKIII Supra be very responsive, torquey, a linear powerband with good top end. To extract very good power on pump gas only. The car will remain very streetable and simply made. (Dont tell me to buy a V8, I'm not going to make my thread all about that). 500whp is the goal on pump gas. I will be spending 98% of my time in this car using it on pump gas, it will see C16 but only as an added bonus after I build it for pump gas 93 octane only.
Build:
Stock 2JZ-GE VVT-i Motor
GT35R (T3) .82A/R
TT Head Gasket (Bringing the compression down to 9.0:1)
Custom intake manifold plenum on stock lower runners
Port Matched Head
Custom Garrett 3-Row Intercooler Air-to-air
MR-S Shimless Factory Buckets
1JZ Lightened Flywheel
Lightened Pullies
Phenolic Intake Manifold Gasket (Lower Intake temps)
ATi Crank Dampener
Pro-EFi 128 Standalone
Theory:
The 2JZ-GE head stock for stock versus the 2JZ-GTE head flows better till a certain point, apparently sub-650hp according to a lot of people that have been building motors and in the business of making power. This is back up by having bigger exhaust ports, but slightly smaller intake side. The intake side being port matched has yielded good gains in CFM flow. The exhaust ports on the 2JZ-GE are straighter and on the TT head there was a sacrifice made in the head to make the sequentials fit.
I dont want to retain the high-compression from factory and using the TT head gasket will allow me to drop it down to a more modest 9.0:1 compression. Giving me outstanding off-boost response and faster spool. Some of you may say that 8.5:1 versus the 9.0:1 is not that big a difference and just lower it so you can run more boost instead. But I rather have a torquey low-end, responsive power with less boost. I will still be able to run a decent ~17-18 psi on it, so long as I have a good efficient front mount intercooler to keep intake temps low along with the phenolic intake manifold adapter to keep heat out of the intake tract. And a very good tune with my ProEFi-128 will make the setup stable.
The lightened pullys wont make that big a difference, but it should help with responsivness. Anything you take off the rotating assembly the better, so the pullies should help, along with the lightening flywheel, the shimless buckets too.
A 264 exhaust cam will give me a more aggressive top end with out the power falling off as I go higher in the rpm band. And last but not least, the VVT-i function. It is a fact that VVT-i's make better torque and horsepower numbers when compared to their fixed cam rivals. The VVT-i will allow me to spool faster, give me even more bottom end torque and very good top end as well. All controlled by a Pro-EFI 128 for reliability and consistency sake.
Misc.
I have a ton of information and ideas. This is more of a final product on my idea, but I'm very flexible on it. I dont mind the critique or any questions. If you have a question on why I chose something, I have good reason for it. Please feel to ask me, and I will provide info!
Goal:
Build:
GT35R (T3) .82A/R
Port Matched Head
Lightened Pullies
ATi Crank Dampener
Theory:
Misc.
