I am experiencing the weirdest problem with my power steering.
89 ma70 turbo.
progressive power steering rack.
1jz swapped.
I have been running my car with no power steering. I looped the rack with a reservoir to keep fluid in it so I dont ruin the rack. I decided that I want to run the power steering again and began the install yesterday. I am using an after market reservoir, as well as the Drift Motion high pressure line. The reservoir is not in the factory location but is above the pump. I also know I have the lines hooked up properly(pressure and return lines are not mixed up on the rack)
Now the problem is, after the car has been running for 15-25 seconds the reservoir starts to overflow. Not really badly but it pushing through the breather hole in the top of the cap. Its to the point where it makes a large mess and its not something I could just deal with.
I am seriously lost and have done alot of searching through the forum and still have not found anything useful. Any suggestions are welcome.
Thanks for reading.
89 ma70 turbo.
1jz swapped.
Thanks for reading.
