Is it common for Clevitt main bearings to not align w/both oil holes on the block. Both of the #1 oil holes line up, but only one of the #3 holes line up, and the other about 3/32 off.
Was the block drilled wrong? Should I drill the bearing out on the one side to align with the hole, or is better to leave the bearing as is?
Search only turned up the 7m tips, while helpful, it didn't address this problem.
Pic
Pic
