i recently upgraded to v4.8. after upgrading, i did a reset and put in my base settings. and so far everything has been going smoothly except for a few things.
1) i have my vf signal hooked up to maftpro via aux1. since i installed the pro, ive been experiencing a wierd issue. when i first start the car, the aux1 gets no reading. even after i warm it up, nothing, 0.00V. my afr are a bit high around 15-16 at idle and the ecu doesnt compensate very well during cruising. if i shut the car off after its warmed up, and start it again, everything is fine and i get a vf reading around 2.3-2.4V. anyone else having this problem.
2) about 2 days ago my vf signal started reading a little higher than usual (after i restart the car when it warms up). it used to stay around 2.3-2.4. all of a sudden its around 3.2 at idle, and goes up to 4.43 once i start driving. and it stays pegged 4.43 even after i stop driving. now my afr at idle is around 13.6 at idle. i havent changed any fuel pressure or settings except boost control. cant seem to figure out what happened to change this.
3) does anyone know where to get a quick start guide for v4.8. i know the settings are similar to v4.4 but there are a few other features that im not familiar with.
4)and finally, in tunerpro, i dont know how to create a new bin file. or where to get a bin file for v4.8.
any help would be great. ive been searching everywhere for some answers but have come up with nothing. i am trying to get these kinks ironed out before the etown meet this saturday.
thanks a lot
-pete
thanks a lot
-pete
