I'm posting up my settings here, of course my setup is different, so......
I have dual walbros, -8 line, afpr @32, 680cc injectors, ar3923's @ .027, ported/polished head, 1mm o/s valves, hks long runner, t-61, big I/C, built auto, 32-3400 stall, q45 (the diff here is my tps reads .41- 4.9x v)
veh sel -0
#cyl-6
disp-3.0
airfl mode- speed density
map source- gm 3bar
load srce- use map
baro mode- sea level;
f-out- supra mkIII
v out 1- use setpoint
v-out 2- use setpoint
afr srce- dynojet
f-in mode- 20 (for timing monitor) Chriso you should do this!
aux1 mode- trig off
setup:
mainscale- -23.0
v-out 1- 2.5
v-out2- 3.6
after start 2.2
lo load pt- 36.4
mid load- 100.1
hi load- 143
f out max- 0
fe smoooth- 30
use ve table #1
spk base- 15.0
tm base- 1.9
tm correct- 1.27
af tr delay- 0.0
boost control:
tps spool-1.90
rpm spool-2494
tps start- 2.50
psi start- 16.0
dc% start- 55.2
psi set-20
psi aux-22
gain- 10
dc% aux-50
afr tracking
Min TPS 2.50
Min RPM 2400
Min MAP 166.4
Lean Lim% 17.5
Rich Lim% 25.0
Gain 5.2
AFR2000R 13.6
AFR3000R 12.5
AFR4000R 11.5
AFR5000R 11.5
AFR6000R 11.5
AFR7000R 11.5
AFR8000R 11.5
Aux % 0.0
Air Temp
-40.00 0.0%
13.00 0.0%
41.00 0.0%
62.00 0.0%
82.00 0.0%
103.00 0.0%
129.00 0.0%
173.00 0.0%
212.00 0.0%
Aux Triggered
All 0.0%
Tuning
RPM High Mid Low
400 0.0 0.0 0.0
800 0.0 +14.0 +15.0
1200 0.0 +15.0 +10.0
1600 0.0 +10.0 +5.0
2200 +5.0 +10.0 +5.0
2800 +5.0 +10.0 0.0
3400 +3.0 +10.0 0.0
4000 0.0 +10.0 0.0
4600 0.0 +10.0 0.0
5200 0.0 +10.0 0.0
5800 0.0 0.0 0.0
6400 0.0 0.0 0.0
7000 0.0 0.0 0.0
7600 0.0 0.0 0.0
Tune Response
TPS Enrich 0.40
TPS Delay 0.60
TPS Size 6
TPS MAP Max 104.0
MAP Enrich 0.1
Boost Enrich 0.1
MAP TPS Min 0.800
MAP RPM Min 2560
MAF Limit TPS Threshold 0.00
MAF Limit 0.00
MAF Limit/KRPM 0.00
Timing Monitor
Spark WOT Spark Aux
2000
2500
3000
3500 all at 15.0
4000
4500
5000
5500
6000
6500
7000
7500
8000
PT Tracking - not using but this is what I tried
Idle TPS .44
Idle RPM 1088
Idle A/F 13.9
Cruise TPS 1.90
Cruise RPM 2208
Cruise MAP 91.0
Cruise A/F 14.5
Lean Delay 5.0
Gain 5.0
Lean A/F 15.0
I am running and idling and cruising fine, not much to complain about other than boost creep, which Mike has had the same prob and gave up on the boost control. I think it may have to do with the gain, when I get time I will tweak some more. I hold real close to 11.5 at wot in 1/4 mile, it creeps a little leaner at 6000+ so I will richen that up. My main issues I had were b/c which I am almost good now, The throttle response used to suck ass, but its great now with 4.65, I havent used timing control, and wont til i see what other people do and whats safe. I occasionally hit fuel cut under certain conditions, passing on highway mostly, never in a straight 1/4 mile pull. I do get a little lean idle miss under hotter conditions in closed loop when a/f is leaner than ~ 14.5. I dont believe thats a maft pro issue, it did it b4, but Id like to tune it out, even though it wont hurt any thing. I will post this in your FAQ thread also Mike. These settings would not benefit someone to copy unless the same setup, but at least we can look at each others and say "hey, why do you have that , what did it do for you". Start helping each other out, I have been frustrated at times I admit, but I still love it.
