Ok so first off let me say that very few of the maft pro links in the maft pro archive are working so i have to post instead of reading and figuring out for myself. So anywho i have Maft pro version 5.0 speed density with boost controll, my mods are 50 trim ct-26, bigger spearco i/c, 2.5 inch hardpipes, full 3 inch, AFPR, walbr and 12v mod, i have stock 440 cc injectors my fuel pressure is @ 40psi w/o vacuum Stock 02 unplugged AEM wb
Here is my problem, I tune PT and it is great untill i shut the car off i get back in and fire it up and after cold start enrichment is done it's like i never tuned it.
the other thing that is confusing me is why do i need to add fuel anywhere when i was untuned @ 16 psi with the stock afm and a fcd on stock fuel pressure my car, under boost stayed very rich (10.2-1 afr) now on both my mid and WOT maps i am adding fuel and my low throttle map is the only one i am taking away from. It also seems like AFR tracking does'nt even try to correct anything. I am just trying to figure out what if anything i'm doing wrong. maybe have my AFR tracking setup wrong? :1zhelp:
all my constants and scalers are setup correctly the only thing i question is the manual said to se mainscale @ 0 b/c i have 440s. Any help would be greatly Apriciated.
thanks
-Zac
thanks
-Zac
