maft pro setup with a 2j, can it be done?
spoolint78
Representing T.O
T.O
Just picked up a mkiv and wanted to take the maft pro out of my mk3 and install it in the mkiv. I just wanted to confirm first though that it will work. I think it could because I see mkiv guys running map ecu's and i know a few mk3 guys are as well. With that in mind the maft pro wiring is pretty similar to the map ecu.
I would much rather run the maft pro then blow 1g on an aem setup.
Any info is much appreciated guys.
thanks
spoolint78
Representing T.O
T.O
version 5?
Is this referring to the software? or the unit? If its the software that's great because I can load it onto the maftpro
