Hey all. I am just now getting around to installing my full maft-pro kit. I know that I am going to be wiring/soldering a ton. I was wanting to make my own plug-and-play harness connector that would allow me to revert back to stock if I ever wanted. Something that would do either one of two things (picture below):
1) go between the ECU and the harnes plug in - ECU ]=--=[maft-pro]=--=[stock_harness, and where the "==" are would be a multi-pin connector. This option is a little doubtful since the ECU plugs are probably more unique than the maft-pro plugs.
2) splice/tap into the stock harness and have a pin plug connect to the maft-pro - ECU]=[stock_harness]=---=("T" off the maft-pro). This method would utilize an end cap of sorts to revert back to stock if need be (that would provide a simple loop to keep the wiring connected).
I know this is way over-simplified and that there are other connections, I am just using this to show people what I'm talking about. The red wires represent the stock wiring and the blue wires represent the new maft-pro based wiring.
I know that the stock harness plug would probably be hard to find. Does the maft-pro use standard pin connectors (I know next to nothing about the standards, if any, of pin connectors)?
Has anyone done this before? I searched and all I found were dead maft-pro threads and tuning threads.
