MAFT Pro install help needed; but, only with the HAC...
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
I'm down to my last wire and can't figure out where it is. The maft instructions aren't clear enough for me to figure this out. I know...I'm a little slow... ;)
So, where is the HAC wire location so I can finish my install?
91 Turbo 5 Speed and I'll be running the maft in AFC mode. For now anyway...
Thanks!
I just read on full throttle's website where the HAC signal connection is optional. For those that have already installed your maft, did you connect the HAC wire or not. Pros...cons...?
jdub
Feb 10, 2006
10,730
Valley of the Sun
The HAC is inside the ECU on the 91 TCCS ;)
(It would be rather difficult to connect it)
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Full throttle will mod your ECU to give you an external wire to connect to if you send it to them.
Alternatively, if you're REALLY steady with a soldering iron, you can do it yourself. I've got the instructions posted up around here somewhere with pics.
CajunKenny
Nov 15, 2007
3,255
Washington
I am an Electronics Technician so that'd be right up my alley!! I'll search around; but, if you can remember where you posted it, please send me the link!
