For those of you that have pulled your 7M motor and put it on an engine stand, have you noticed what size the factory bolt is that bolts the bellhousing to the motor? On mine it is the size stated in the title. Are yours the same? Also did you end up drilling and retapping the holes to a different size or did you make the factory bellhousing bolts work to mount the engine on your stand?
