Lug nut broke off the hub!!!
Ckanderson
2,644
The beach
btw, little tip is to throw the new stud in the freezer for about an hour or two before actualy attepting to put it in.
PROJECT N00b
XBL: Mkiii DriFt3r
May 22, 2005
1,660
honolulu, california
Jeff Lange said:
So did the threads strip, or did the splines on the knurl of the stud strip inside the hub?
I'm thinking the latter?
It didnt strip it just broke off. And the bolt is in the nut.
Ckanderson said:
btw, little tip is to throw the new stud in the freezer for about an hour or two before actually attempting to put it in.
So if i put it in there and then try to get the thread out it should come out?
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
He said put the new STUD (see bolt, lug, long metal thingy with threads on the OUTSIDE) in the freezer, not the lug nut.
JASONA70
nomnomnom
Oct 27, 2006
743
socal
ehh if your really cheap and dont wanna go get a new nut, i use a small drill bit and drill it in the stud and then i reverse it and it should come right off. unless you torqued it at like 50pounds or something. i dont know if ill have time to help you. i have to start the roll paint job with my friend. we are seriously slacking off. i want to get it done in a week and a half. oh btw you still on for hooters??
