ok so me and hottscennessey have been talkin back and forth on pm so i figured i should probubley make a thread to display all the useful info we were talkin about... and at the same time make a build thread.
so heres a little history on my supra....
so i bought a 88 turbo auto targa with 64000 original miles for 1200 bucks back in april 07. i quickley started to strip it down to make it nice again.
so wile working on the appearance i also started on the motor (7m) i built it up with forged internals and everything unholy....
ive had my 7m built and running with stock boost and fuel for a little less than 1500 miles now... and i found a smokin deal on a 2jzge had to take it. so now the 7m is out and the 2j is goin in just as soon as its cleaned up and got the thicker hg in it.
i still got a bunch of questions on this set up...
i guess ill just list them.. lol
- oil drain and feed for the turbo
-do i have to modify the 7m cps to fit?
- what coils can i use?
-how thick is the stock 2jzgte head gasket? is it thick enough to lower the compression good enough for 20- 25 psi?
-1jz flywheel?
-are arp head bolts/studs necessary?
-will rc 550's work with the stock ge fuel rail?
im sure i will have more questions as i go along with wiring and stuff...
thanks for the help!
-1jz flywheel?
