guys i need help:1zhelp:
the little ball joint looking thing on the lower suspension arm that bolts to the hub assembly, how do you get it on??? i knock it with a hammer to get it off, the tsrm says use a sst to remove it so do you use the same tool to install it??
thanks for the help!!
